Structure Modeled in Physical Modeler to STAAD Advanced Concrete Design
Hopefully someone can answer this. I created a concrete structure using STAAD.PRO CONNECT EDITIONs PHYSICAL MODELLER Workflow. Then after that I also analyse it using the same software. Save and close the file.
To finish my design, I opened it in SACD-RCDC but to my disappointment SACD was telling mw that column is missing.
But if i tried to open it in v8i and remove all physical member properties, SACD works.
My question, IS IT NOT ALLOWED TO DESIGN A FILE WITH PHYSICAL MEMBER? OR THERE IS REMEDY FOR THIS ONE?
Parents Reply Children
