Please see screen shot. The new RCDC connect cannot read the MDB files from ETABS! Please assist
Invalid link sir . Can i request a new one?
please find the link to download : https://bentley.sharefile.com/d-s0628eff93664861a
Link is not working, same issue
Please click on the new link to download the same : https://bentley.sharefile.com/d-se9a5368ecd54c3e9
maam I am facing the same problem like Falcon and Kamran is facing. my office version is 2019 64bit, Etabs 18.1.1. i have tried installing both ways as mentioned by you in the above thread yet not solving the issue
Hi Ronnie , as per the screenshot please remove the earlier version of access database engine 2010 and install the 2016 32 bit in your machine. The link is attached for the same: https://bentley.sharefile.com/d-sc960e4a5f014e2fb
Try this and if this also doesn't work then would recommend you to raise a Service Request and i will assist you further.
Dear Friends,
This database file exchange problem is due to "Access Runtime Driver(ARD)" problem in your respective machines as mention by @Ranjana Shinde is a right answer/solution for all of your questions/problems.
There are several options available to update ARD in your machine, you just google it "Microsoft Access Database Engine 2016 & download x86 or x64 bit version" depending upon your machine processor architecture.
Uninstall old version of ARD (2007/2010) & All MS Office Applications (if you are installed) from your machine before going to install ARD 2016.
Now try to install "Microsoft Access Runtime Driver 2016" which you download by above reply by Ranjana Shinde or you can download by links mentioned below in my replay which are from Microsoft Website.
Go to Control panel in your machine & make sure "Microsoft Access Runtime Driver 2016" is installed.
Open RCDC application & Check.
Update for Microsoft Office 2016 (KB4018295) 32-Bit Edition:
www.microsoft.com/.../details.aspx
Microsoft Access Database Engine 2016 Redistributable
Also you can try to install Microsoft Access Runtime Driver 2016 using command prompt (DOS) with /quite mode option to avoid any GUI installation problem.
docs.microsoft.com/.../standard-installer-command-line-options
In my machine RCDC is working fine with ETABS 2018.
For any help or assistance you can write a mail to me.
Kiran
Structural Design Engineer
This works for me thanks
