I usually use this command to run STAAD models. I use it in a loop, so in each loop std.std is a different model. That's handy.
dos('C:\SProV8i\STAAD\SProStaad\SProStaad.exe /s std.std');
But with the STAAD Pro Connect Edition, the command doesn't work anymore.
I have updated the .exe folder location, and STAAD is opened. but the model is not run.
Thanks in advance.
regards, Huijun
I linked to the wrong executable file. It is running now with the below command.
dos('"C:\Program Files\Bentley\Engineering\STAAD.Pro CONNECT Edition\STAAD\SProStaad\SProStaad.exe" /s std.std')
Hi sir,
I'm Engr. Nico Ruz, a student from Philippines, may I ask if you could provide me some your matlab codes in connecting staad to matlab. Thanks sir.
nicopauloruz@gmail.com
