3 STOREY APARTMENT WITH ROOF DECK 2.0.STD
have you guys experience this when you set ductile option in RCDC 8.0?
RCDC works fine when i set it to special,
when I try intermediate option
it will stuck in not responding.
please refer to attached files. thanks
As mentioned by you we have checked by both ways (ductility check) with Special as well as Intermediate option , the design was performed without any issue in the program. We would like to know if you have incorporated any other settings in the file so that we can check it again with the new changes as well.
I'm getting "not responding" when I check intermediate in ductility check. I'm using the same std file in rcdc 8.0.
if it works in your rcdc maybe I need to reinstall my rcdc?
Yes you can reinstall the software one time and check the same . If the issue persist then we would recommend for an remote access via Team-viewer to your machine and investigate issue further .
Currently reinstalling my software. I'll give you an update soon. thanks :)
I see, when I put a member load for my chb I'm getting this error. I've tried to remove the member load and it works fine.
but my model needs to have a member load, any suggestions?
