I am unable to generate seismic parameters in staad pro (connect edition). I could use seismic parameters many times using staad connect edition. It is not working for the last 2/3 days. Kindly help me. The screenshot is as follows:
Uttam
I think the safest bet is to uninstall the software and reinstall.
Thanks.i tried the process (uninstall & re-install).the problem still remains..kindly suggest whom to contact in Kolkata.I'm really facing big trouble.
Can you please perform the following steps and let me know if your issue is solved?1.Close all STAAD applications.2. Go to the following locationC:\Users\<User.Name>\AppData\Local\Bentley\EngineeringWhere <user.name> will be your name or the user who is using STAAD.3. There will be a folder named “STAAD.Pro CONNECT Edition”. Rename the folder to “STAAD.Pro CONNECT Edition_1”.4. Right click on the STAAD icon now and select the option Run as administrator.
Thanks for the quick response. I tried, the following error appears:
I am having same problem. Did u find any solution for this
