When I'm using round/rectangular HSS non-A1085 I keep having warnings in my output saying that the HSS is non-A1085 and thickness wouldn't be reduced. I understand the meaning of this but I would like to ask on how to remove warnings like this when I'm going to print my STAAD output. Is there some button I need to press or command to type?
Thank you.
As of now there is no way to turn these warnings off from the anl file but this has been logged in our system ( Id# 1009530 ) and very soon you will have a way to turn these off.
I would like to ask if there's an update regarding this. Thank you.
For the records, response to the above question has been posted at
https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/183014/follow-up-on-warning-non-a1085-hss
