Greetings, Recently i modeled, analyzed and designed a RCC frame structure and i got a 12 messages stating ""TOTAL NO. OF JOINTS IS GREATER THAN 999"". What is the meaning of ""TOTAL NO. OF JOINTS IS GREATER THAN 999"" as shown in above pic. Does this affect the analysis/design results? Also whats the solution to clear this message?
Waseem M.A
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/25288/maximum-model-size-in-staad-pro
https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/158830/staad-pro-connect-edition-note-total-no-joints-is-greater-than-999
Please refer the above links to know the probable solution. Also if you are unable to find out the reason please upload the file here for investigation.
Thank you for the reply/answer...
