Ram Elements Single Angle Compression
For single angles in compression, it seems RAM Elements either uses AISC E5(b), which is unconservative (planar box unchecked, default), or uses KL/rz, which is too conservative (planar box checked), is there a way to have it apply E5(a), when designing an individual single angle member?
