I am trying to model the frame from the RAM Structural System Tutorial. Inside the RAM Frame module, I performed the Joint Check which outputted all joints to be "OK" However, when I check the joints through "View/Update Joints" It shows a red signal showing "No beams fixed to column flange". I had modeled the beams between center-lines of adjacent columns. Am I missing a step in between?Your help is highly appreciated. PFA a screenshot of the error. Thank you.
Assign the beams in the Moment Frames to have all end conditions fixed (XXX). Also double check the column alignment. The completed tutorial files are installed in this folder by default: C:\ProgramData\Bentley\Engineering\RAM Structural System\Data\Tutorial
Thank you very much, Seth. Fixing the end conditions worked for me. I appreciate your help.
