Hi all. I am using Ram to do gravity design and try to assign deck. However, I can assign deck to all the floors except one of them which has the same structural layout as others. I am sure that there is no deck assigned. Also Tried to delete the deck several times. Therefore, I just want to know why it is happening and how I can fix it? Thanx
Mar 15 Gravity Design.rss
Can you please attach the model?
Run the data check. If there is a break in the slab edge fix it, then try again.
Thanx. But I tried but still doesn't work. Even deleted the slab edge.
In that case you can manually apply the deck in a large rectangle covering the whole floor. If there is some error that the data check missed, it will show up when you go to run the "framing tables" See also:
Sure. Thanx
