Hi all. I am using Ram to do gravity design and try to assign deck. However, I can assign deck to all the floors except one of them which has the same structural layout as others. I am sure that there is no deck assigned. Also Tried to delete the deck several times. Therefore, I just want to know why it is happening and how I can fix it? Thanx
Mar 15 Gravity Design.rss
Data check shows no error. And I cannot manually apply deck because the "add" icon is grey. Can you show me where "framing tables" is? Thanx
Perhaps your problem is more basic. You need to select the deck type that you wish to apply to the layout before you can click Add, Whole Floor etc.
Here's our online tutorial: https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/2713/ram-structural-system-tutorial
Here's our training: RAM Structural System learning paths on Bentley's LEARNserver.
Thanx! I did select the deck type but the add icon still didn't work. Even I created a new model, it still didn't allow me to assign deck to the second floor (which is the first level to start the structure of the building) Just confused about why it works for every floor except that particular one.
First, you have so assign Layout Slab -> Slab Edge then do the Deck Assign
Answer Verified By: Seth Guthrie
