difference in steel design results
please check the code attached. I'm trying to design a purlin section on staad pro using various indian codes. in steed design result is800  and is800 2007 WSD failed the section  BUT IS800 2007 LSD passed the section. should I consider this section passed or failed. please help me understand.
STAAD SPACE
START JOB INFORMATION
ENGINEER DATE 03-Apr-19
END JOB INFORMATION
INPUT WIDTH 79
UNIT METER KN
JOINT COORDINATES
1 0 0 0; 2 3.7 0 0;
MEMBER INCIDENCES
1 1 2;
DEFINE MATERIAL START
ISOTROPIC STEEL
E 2.05e+08
POISSON 0.3
DENSITY 76.8195
ALPHA 1.2e-05
DAMP 0.03
TYPE STEEL
STRENGTH RY 1.5 RT 1.2
END DEFINE MATERIAL
MEMBER PROPERTY INDIAN
1 TABLE ST ISMC75
CONSTANTS
MATERIAL STEEL ALL
SUPPORTS
1 2 FIXED BUT MY MZ
UNIT METER NEWTON
LOAD 1 LOADTYPE Dead  TITLE DL
SELFWEIGHT Y -1
MEMBER LOAD
1 UNI GY -152
LOAD 2 LOADTYPE Dead  TITLE LL
MEMBER LOAD
1 UNI GY -497
LOAD 3 LOADTYPE Dead  TITLE WL
MEMBER LOAD
1 UNI GY 1000
LOAD COMB 4 COMBINATION LOAD CASE 4
1 1.0 2 1.0
LOAD COMB 5 COMBINATION LOAD CASE 5
1 0.9 3 1.5
PERFORM ANALYSIS PRINT ALL
LOAD LIST 4 5
PARAMETER 1
CODE INDIAN
CHECK CODE ALL
PARAMETER 2
CODE IS800 LSD
CHECK CODE ALL
PARAMETER 3
CODE IS800 WSD
CHECK CODE ALL
FINISH
  • Dear User,
    You have used 3 codes in the file. Every code has some design philosophy and methods. They are different from each other. IS 800 & IS 800 2007 Wsd are based on working stress method. IS 800 2007 LSD is based on limit state method. Now there are differences in design methodology for WSD & LSD. In WSD we work with a stress within elastic limit. In limit state we can go beyond elastic limit.  Please refer some standard book to know about this.  Also, the load combinations used here is not okay for IS 800 1984 code. So, the results will not be same for all codes and they are passed or failed as per that particular code prohibitions.
    Thanks & Regards,
    Abhisek Mandal
    Global Technical Support
  • thanks for your reply sir, also can u tell me what should be the load combinations in this particular case(for is800 2007 LSD and WSD), and which approach should be preferred( LSD or WSD). what is preferred by the designers for better practicality, safety and economy.
