RAM Concept: Precompression values on Design Strips
HI, Can anyone clear my following queries from RAM Concept
1) The Centroid stress plots under the Rule Set design reflects the Precompression forces in the slab ?
2) We have noticed that the precompression value reduces if we put an additional short tendon and stop midway in the slab rather than putting it till the end. When we remove this short tendon, it regains back its precompression values. This shouldn't happen in reality as any additional tendon should help the slab to attain more precompression force. We believe it is because the slab elements are meshed as nodal points and when the short tendon ends, due to difference is displacement between two nodal plates( one with the tendon and one without the tendon), it takes the average of two location and displays the precompression force at that point. Is it true?
Parents Reply Children
