In checking the seismic provisions for BRBF columns, I have a number of columns that are failing the required strength based on E amplified by Omega_o for compression. The Pu for compression in each case is some extreme value that appears to be an error. This is happening in random column segments throughout the model. It appears to be isolated to D1.4a(b) in compression. Sample output attached for reference.
Please share your model using the Secure File Upload instructions on the web page below and post back here after it is uploaded.
Secure File Upload
Sorry, Karl - I just uploaded the current file. I reduced Omega down to 2.5 from 3.0 (was using this for SidePlate frames in the transverse direction) and it seemed to fix the problem. Today, I was tuning some parameters and noticed the same behavior return on column 96 at the second story. The Omega_o tension value is much much higher than the story below. Any clarity on this item would be greatly appreciated.
Thanks.
