Dear admin,
Which STAAD.Pro version are you running? If not the latest one, try to upgrade to STAAD.Pro CONNECT Edition version 22.00.00.15 and see if that helps.
I already tried to run using STAAD.Pro Connect Edition, and the errors still same sir. Is there any other suggestion for this issue?
Are you running the model from the network drive? If yes, please copy it into your local hard disk and run it from there. If that does not help and still the same error occurs even in STAAD.Pro version 22.00.00.15, please attach that model for the investigation. Thank you.
Sir, already settled. Thank you for the response.
Hi sir, I had the same problem, and I tried both way but still didn't work, here is my file, please help, thank you!Bridge Model TH.std
