When I place the seismic load by horizontal force it does not take into account the torsion of the structure. Thanks regardsJorge Hugo Correa
Hi Jorge,
Please attach the related model.
2072.DEFLEXION.STD
Seems like the graphic user interface (GUI) is failing to add the DEC 1 command in the input file even after one chooses the appropriate option in the GUI. This looks like a software glitch. So for now, I would suggest that you enter the DEC 1 manually.
Here is a sample input
LOAD 100 LOADTYPE Seismic TITLE SL IN X
COLOMBIAN LOAD X 1 DEC 1 ACC 0.05
Defect #1022585 has now been logged for this issue and it will be addressed. For the records this issue seems to be specific to the Colombian code. I tested it for the IBC/ASCE and it seems to work as expected.
