Hello everybody
To design SCBF I must work whit the expected brace strength in tension and post buckling brace strength in compression and calculate the forces in columns whit the result forces amplified by omega.
Whit this results I must to calculate the SCBF connections. My inquiry is.
Ths seismic frame in RAM CONNECTION is the tool for this situation.
Here are the steps.
Hello mister Seth Guthrie
What is the advantage of using the seismic frame? Or how useful is this tool?
