Under loading section in Seismic parameters, the drop down box appearing is blank and is not accepting values pr codes.Staad_Prob.flvThe video for the same is attached for reference.
Can you please perform the following steps and let me know if your issue is solved?1.Close all STAAD applications.2. Go to the following locationC:\Users\<User.Name>\AppData\Local\Bentley\EngineeringWhere <user.name> will be your name or the user who is using STAAD.3. There will be a folder named “STAAD.Pro CONNECT Edition”. Rename the folder to “STAAD.Pro CONNECT Edition_1”.4. Right click on the STAAD icon now and select the option Run as administrator.
