Please feel free to ask your questions or post your comments here on this discussion thread regarding the webinar, "Design of Tilt-Up Concrete Buildings."
If you need to efficiently design tilt-up concrete buildings, RAM Structural System has what you need! Join this webinar to learn how RAM's modeling environment and special tools for tilt walls improve efficiency with a full 3D model as well as improves accuracy in your strength analysis.
Structural engineering expert, Eric Helmueller, will show you how to:
Want more?
Thank you for the clarification on the timeline. I was just at an ACI 318-19 seminar all day yesterday where Dr Wight and Trey went over the code changes. For sure shear equations is going to be big change, hooked bar development length...anyways these changes are going to be interesting communicating to clients...as an footings have just gotten deeper with the code changes....If you are planning to implement the ACI 318-19 changes that would be interesting for us to explore the software further.
Thank you
Is this webinar still available to watch? I can't seem to find anywhere and the link is dead. Thanks!
The link above should work now. There is also one more recorded workshop that you can access here
Perfect, Thank you!
Hi Eric,
I have tried using DA Tilt-up Tool spreadsheet. But it is producing wrong values of OOP BM and showing the width of openings as 0 in most of the panels. If you have some tips to use this tool effectively, It would be highly appreciated and helpful.
Thanks & regards.
