Error- with nonlinear analysis each load case must be followed by perform non linear analysis then change
Dear Admin,
I tried performing the nonlinear time history analysis feature in STAADPro, but in the end, errors occur. This error says that "each load case must be followed by performing nonlinear analysis then change." I also get a solver error.  After I made some modification, another type of error appears again, and state, "above command is not recognized, line ignored." Do you think the dynamic load case have desired configuration? If not, how the arrangement should be? With this, I attached some screenshots command file for your reference. Thank you
