Hello I use RAM connection program in conjunction with Staad Pro analysis program where in for any connection design the forces in a member/joint is directly available from Staad.
However I never used LIMCON. Can I use LIMCON in conjunction with Staad pro Analysis to get the forces for connection design? Can anybody give few steps to start with my practice?
Limcon is not integrated with STAAD.Pro. You need to analyze the model in STAAD.Pro and then collect the forces at the joint and enter it into Limcon manually.
