HELLO,
I WOULD LIKE TO ASK HOW TO CHECK SOFT STORY, STIFFNESS CHECK AND DRIFT CHECK IN RAM STRUCTURAL SYSTEM.
THANK YOU
In Ram Frame you can use the Report - Story Displacements or Nodal Displacements to get deflections. Process - Results - Drift is also useful for checking at the corners of rigid diaphragms. There is a report called "ASCE 7 Stability Coefficients" report that will also be useful, but we don't directly check for soft-story. See also: https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/2980/ram-frame-seismic-loads-faq
Answer Verified By: Julimar Sundiam
Thank you,
