I have a fairly simple structure (so far it consists of steel beams, joists, girders and columns, and concrete tilt-wall panels) that I'm trying to analyze in Ram Structural System but it seems that a lot of the model is lost in translation. The Model exports from Revit 2019 to an ISM file with all of the necessary structural components mapping (the ISM model is identical to what I see in Revit). But then when I try to bring the ISM file into RSS, it doesn't recognize that I have any steel beams and it can't seem to find half of the columns. Any suggestions for what I can try to get my full model into RSS?
Make sure to use the latest versions (currently RAM SS - 16.01.00.06, Synchronizer - 10.03.01.06, ISM Revit plugin - 10.03.00.08). I tested this with a user yesterday and I saw good fidelity. There are some items RAM SS cannot import because some materials and geometry are not possible in RAM SS. If your case is clearly something that should be coming across then send us the files. Secure File Upload
Ok, I see that I'm behind on the RAM SS update, but I'm up to date on the other two. I'll get that updated and see if it solves everything.
We certainly made some improvements in Ram Manager for ISM import in the last couple of versions that are worth having.
Ok, everything is up to date - still not transferring everything. Can I send you the .ism?
Yes, you can insert it into your reply or post to Secure File Upload
