Hi ,
i trying to develop custom tool using openstaad + c#.
i want know what is reference .dll name and where its located in staad installed path.(specially connect edition)
your sample Excel macro is working fine in my system. in this new version i not able find openstaadUI reference .dll.
i want known whether openstadd is separate installation and need separate license to develop custom Tool? if not can you guide us how find reference .dll.
Hi Rathod,
No. not find any solution yet. i am looking solution from Bentley Dev Team.
Ok.No problem.Thank you.Please let me know if you get any updates/solution.
Hi Badrz,
any update from development team.. already my tools are developed in Select Series 6 version + C#. Really worrying how to make this tools should run for Connect edition. we need your Support to get solution for this issue
i am having same issue, what's point of all these features if we can't use it. i tried to contact dev team but each reply take few weeks and i finally gave up on it , there are only two options currently either switch to old version or switch to VBA
Hello All,
Adding StaadPro.dll will not help in C# application. You need to add the interop dll. Please create the dll by following steps:
The output DLL will be found in the folder where your command prompt is pointing.
Now, add this dll to your C# project and you can access the OpenStaad application object.
Let us know if this has helped.
Rudra Lahiri
Senior Principal Software Engineer, Structural
