Good day,
Is it possible to assign the seismic loads generated by STAAD to specific frames in my building, rather than have the program assign the loads to all frames in the direction under consideration,as is normally done? If so, how can this be achieved?
For example: In a case where I have 5 frame in my transverse direction and I only want to use the 2 end frames to carry all my seismic forces, how can I achieve this in STAAD Pro.
The automatic seismic load generation is going to consider all the frames. The only way I can think of handling this is to go through with the automatic seismic load generation first to find out the generated forces at all the nodes. Subsequently create a seismic load case and manually assign the loads as needed ( based on the automatic load generation ) and then take out the automatic load generation.
