I am modeling a PT flat plate slab in RAM Concept. Actually, I am modeling an existing building. Is there a way I can input user defined SSR for punching shear? I am trying to model and match the existing stud rail. Thank you,
You can define different stud rail systems under Criteria - Materials (stud diameter, Fy, etc), but the program always designs SSR layouts. There is no user defined SSR layout yet.
Thank you, Seth.
Would it be possible to add the ability to input user SSR in a future update?
Yes, we'll add this eventually. (Backlog Item 568913: User assigned SSR (check punching shear))
