I would like to ask if there's a way to print only the Steel Design. I notice that it's included in the output but is there a way to only print the Steel Design.
I am using STAAD Connect Ed.
Thank you.
The screenshot below shows how steel design details can be included in the report:
Hi Modestas,
I am following your instruction but Steel design detail is not available in my output list. Is this the limitation of my version or something wrong that I I have done? I using Staad Connect Ed.
Some codes (i.e. AISC 360-16) do not have this option yet. In such case, detailed design results can be reviewed in the Output file.
Couple of additions. For codes like AISC 360-16 for which the Steel Design Detail option is not available till now, you can include the Utilization Ratio Table option in the Report. Also in case you need the detailed design output, you may open the Analysis Output file using the output viewer and then print only the relevant pages that contain the design.
Also for the records, a defect # 1081277 is already there in our system to get this option added for the AISC 360-16 code.
