I would like to ask if there's a way to print only the Steel Design. I notice that it's included in the output but is there a way to only print the Steel Design.
I am using STAAD Connect Ed.
Thank you.
Using Code AISI Unified 2016, I don't see an option in Report Setup / Items / Output for "Steel Design Detail." Did I overlook something? It would be useful to have the same report for AISI as for AISC.
Regretfully, but the "Steel Design Detail" report is not available for the AISI 2016 code yet.
Thanks for the update! And I am more interested in a capability for dampers than I am in an AISI Report.
Any update on this? Thanks.
