Hi there,
I am modeling a PT slab in RAM Concept. I am getting the error "Wall element below the slab is not connected to the slab" when I try to generate mesh. Can anyone let me know how to fix it? Thanks,
Make sure there is a slab object covering the wall CL for the full length. Walls that extend beyond the slab edge or into an opening need to have an extra sliver of slab added typically.
Answer Verified By: Rishav Poudyal
Thank you, Seth.
