I
I dont quite understand how to use KMX , KMY, KMZ to release some of the moments from a support.
What is meant by the unit kn.m/deg. ??
How can I set a reasonable release for the attached STAAD Model , to activate the back fixed support . 4278.Cantilever 2019 - Copy.std
You should not release FY as otherwise the shears even due to selfweight of the members cannot be transferred to the supporting members.
Use the following
MEMBER RELEASE
12 13 16 17 START MY MZ
12 13 16 17 END MY MZ
thanks . ok .
3 - 5 mm deflection does not seem high unless the structure is really sensitive to deflection. Anyway you may use KMX but ensure that what you are using is realistic.
the structure is sensitive indeed , where can i get more info about kmx and rotational stiffness to ensure my numbers are reasonable ?
This is an engineer's call. If you are unsure talk to other engineers involved in the project.
