RAM Concrete Column - Two Story Column Design (Sway Frame)
I have a two story concrete column that is unbraced the full height. Looking at the design results the moment magnification factor (delta) for the top story is 3.8 which I was able to verify by hand using ACI 318-14 Eq. 6.6.4.5.2. However the bottom portion of the column has a moment magnification factor of 17.85, which cannot be verified with that same ACI equation. I believe the program analyzes the two portions as one column, so why are the results that much different? Is this an error or am I missing something?
Shane
