I assigned a uniform load in Kip/ft on a truss. However, the report shows up kip/in. I haven't run the numbers but may be this is something to look at.
PDF
It's working OK for me in version 16.00.00.39. Both show kips per ft. What version are you using? Have you altered the units default in the main program?
It looks like it shows up only before printing. Here's a screenshot.
It is V16 and I haven't changed any settings.
Perhaps it got fixed in my build. If you need to edit the report before submitting, send to Word and make the edit there.
Perhaps. My build is 37. Thanks for your time Seth.
