I'm working in built-up column with four I sections. I'm getting some results and not sure the results are correct. Can someone please check the model is correct?
Thank you.
Built-Up column.STD
Beams 20 and 21 should be intersected in my opinion. I don't see any other modeling issues.
Thank you
