Warnings
Hi Guys
I was trying to fix 3 things in the last couple of days. unfortunately, I could not fix all the problems, so I hope to get help ASAP.
the First problem that I had and I could fix is the warning that says "Review shear min density/max spacing Cl 9.7.6.2.2"    I just increased the cross section area, then the warning did not appear. However, I would like to get comments about the solution that I made or other solutions.
the second problem is that after I removed all warning, I am still not getting design tab (after running the analysis) by double click on the member (the tab I am talking about is to the right of the deflection tab. THIS TAB IS NOT IN THE OUTPUT)
the third problem is that the take off command for the RCC building is not working even without any warning I am still getting 0 CU.meter.
Finally, I appreciate any help, and I can provide the input text if needed.
  • Are there any updates regarding the "Review shear min density/max spacing Cl 9.7.6.2.2" warning message when using the ACI 318-2014 code? Thanks
  • Hello, I had the same question, however analyzing the message of the warning and the point of the indicated standard, I understand that the program is indicating that it is verified or pay attention to those members that are being designed with reinforcing steel at maximum separation for not having significant requirements for shear. But it does not mean that there is something wrong with the design.
    Hola tenia la misma pregunta, sin embargo analizando el mensaje de la advertencia y el punto de la norma indicado, entiendo que el programa lo que esta indicando que se verifique o preste atención a esos miembros que están siendo diseñados con acero de refuerzo a separación máxima por no contar con requerimientos significativos por corte. Pero no quiere decir que hay algo mal en el diseño
  • I created a MathCAD worksheet (although probably easy enough to do in Excel as well) that checks the max spacing (from tbl 9.7.6.2.2) AND the minimum spacing from 25.7.2.1. The spacing the program gives for the transverse reinforcement falls in this range (24 in < 8 in < 1 in). So I'm not sure what the warning is for. It would seem that MathCAD has all the variables to check itself (except maybe diameter of the aggregate), so maybe that's why it is warning the user to check the tie spacing... Or maybe I'm just misunderstanding it all? It is strange.
