I'm modelling a circular silo and assign incline supports and compression only(KFX) supports, but half of the tank support reaction results into X direction is Positive(+) and the other half support reactions into X direction is Negetive (-). Can someone please explain the support reaction in the incline supports is also along Global axis? or towards the point that we define for incline supports?
If its along Global axis, what is the point that we define incline supports?
Thank you
Inclined support reactions are printed in the Output file only when using these commands:
SET INCLINED REACTIONPRINT SUPPORT REACTION
More details can be found here: https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/140157/support-reaction-other-than-global-direction/424626#424626
Answer Verified By: REI
Thank you Modestas
