Dear sir ,
Kindly give me direction how I can check the deflection for the specific beams.stad file and drawing is attached.consultant want vibration check for specific beam.thanks.PDFSTORE.std2.std
gentle reminder
What type of check you want to incorporate? Is there any limiting range to check for resonance? If so, you can use Rayleigh method to calculate frequency for certain loads and check if the frequency is falling within resonance zone. If so, please try to change frequency with increasing stiffness of your structure.
