eurocode check.STD
hello all,
i am using eurocode for the structure design, where load envelope for serviceability not working properly.
eventhough i have specified the envelope, the result is not showing the member failed for stress in the graphical interface
it is giving only the latest parameter result.
I have attached the model.
I have tried in single parameter with both stress and serviceability envelope but it is not checking for deflection in serviceability load cases.
Please advice how to proceed.
REgards
senthilkumar.B
hi
but in graphical interface it is not showing the worst case ratio of stress and serviceability envelopes.
it is showing only serviceability envelope
Only the result of the last code check is shown in the graphical user interface. To see the results of all checks you need to look at the Output file.
if we are designing in american code in single parameter definition both envelopes are checked and results are given for the worst case, but in eurocode design when we specify load envelope and specify single design parameter for both envelope, why it is not showing the worst case results.
regards
EC3 code check works differently then AISC Unified code check. For EC3, you need to create 2 separate design parameter blocks for strength and serviceability checks. It is not yet updated to take advantage of strength and serviceability envelopes in a single design parameter block.
Regarding this issue with deflection check using Eurocode 1993.
I have created two different parameters (one for strength and one for deflection check), and in the output I can see both checks results.. but why in the graphical interface we can not see worst results of both cases?
