Hi All We are having some technical issue while using Staad pro Connect addition
Please coordinate with the technical team to resolve issues
As we do Concrete design in Staad.Pro Connect Software, After Analysis we are not able to get the reinforcement percentage value.
We have done concrete design by AC318 Code.
we have attached a snap of Staad output and staad files for your reference.
But if we follow Indian code for the concrete design we are getting the concrete design values.
Please check and let us know a possible solution.8231.staad model.STD
The Concrete Design tab in the Member Query box is not yet implemented in STAAD.Pro for the ACI 318-14 design code. An enhancement request #822159 is already logged to implement this feature in the upcoming versions of STAAD.Pro. In the meantime, the design results should be reviewed in the Output file.
Sir, we are also having problem with my concrete design as there are no reinforcement percentage value even on the output file. Hope to hear from you soon. Thanks.
You should find the area of steel required in the output file. If you cannot find it, please attach your model and let us know the exact STAAD.Pro version being used.
