Hi All,
Is there a way to Import Revit Model into Staad Pro?
This can be done using the ISM file. You can download (https://softwaredownloads.bentley.com/en/) and install the ISM Revit Plugin in your machine and generate the ISM file (.ism.dgn) from Revit. This ISM file can be imported easily in STAAD.Pro using the File > ISM > New from Repository option. For more details on ISM Revit Plugin, you can go through the following post--
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/23290/ism-revit-plugin
is the ism software free to download?
Yes, it is free.
