Design Strips around shear core.
Hello. I am having trouble modeling design strips on a slab at a shear wall area, which cantilevers out at two sides around the shear core. I am using PT to attempt to limit deflection but I am having problem with top stress failure. I know I may have a problem even in the most optimal scenario, but I am having problem figuring out what that optimal design strip is. The south side of the shear core has a 4ft beam and a shear wall above it. The edges have a cmu block wall and a conc. roof (so the linear load is around 1000 lb/ft. I just needed help in figuring out were I should connect my design strips and under what criteria. There is a bridge at the southern most point being held by a beam to another building so I used a line support load to hold it. SLAB AREA PROBLEM.cpt
Parents Reply Children
