I have floor plate with composite beams and uniform loading but for some reason a couple beams in the top right corner are being designed with partial loading and beam sizes that are substantially larger than the rest of the floor, which doesn't make sense. There are also some beams that aren't showing sizes.
Check this: communities.bentley.com/.../missing-or-incorrect-loads-near-perimeter-beams
ok. thanks!
