While using staad pro vi8 ss6 after designing the steel with the steel design work flow, it gives you the new design steel section. Then I would click the update property so staad can assign the new section given to my model. But now I have moved to the connect edition. I find it difficult to update my newly steel design section using the batch mode method.
After successful analysis, please go to Postprocessing - Results and you will find the option you are looking for, as shown on the screenshot:
Answer Verified By: hakeem olokunola
How to do it in Select Series 6?
