where are we able to check the full strength design calculation for a PT beam in RAM concept?
Our section Audit tool provides the complete set of calculations for any design section. You can use it on the Rule Set Design - Strength Design layers if you are only interested in Strength checks, otherwise use it from the Design Status layers.
Hi, the section audit is a summary of the results in table format. I was asking for calculations, as they are not illustrated in the manual either.
If you expand the information under Final Design - Strength Design (click on the black triangles), you will see much more information in the Auditor. For each envelope, the program will report the top, center, and bottom strains and the resulting force in each rebar or tendon that intersects the cross section. These forces are used to calculate the moment capacity. The Auditor does not show formulas if that is what you are looking for.
