How can I find overall floor area with RAM DA in VBA(total area within all slab edge polygons)? I don't want to subtract the openings/penetrations. I based my code off of the RAM Material Takeoff spreadsheet found on these forums but it is double counting overlapping decks and subtracting opening areas.
I want similar results to the floor area printed in RAM Frame module "Frame Takeoff" report
Our RAM Estimator spreadsheet includes deck area, so I know there is a function somewhere for this (or just use our tool).
Yes that is where I developed my code from but if you have two deck extents stacked it double counts them. I just want overall floor area in order to quantify a takeoff that gives structural steel psf by level.
I think I figured it out via ISlabPerimeter function to get polygon vertices rather than IDeck vertices.
