Crdc value calculation in one way shear for footings as per EUROCODE.
Attached is the verification manual of EUROCODE isolated footing in staadpro foundations advanced.
In one way shear check for footings,how is the Crdc value calculated as highlighted below?
The basic formula is 0.18/concrete factor of safety=0.18/1.5=0.12,but in design it is considering 0.156.(0.18/1.15 hope it is taking factor of safety of steel).
It will make big difference in shear calculation in case of allowable values which are kept closer to actual.
Please check and confirm.
