RAM shear wall section cut forces
I have a shear wall that has section cuts failing right at the corners. When I look at the forces in the failing section the shear is 760 kips and then right next to it is a passing section cut with a shear force of 240 kips. This is a very large force jump. The story below has a similar section cut and has a shear of around 300 kips.  How does RAM Concrete determine the force in the section cut. Which force is accurate to design additional reinforcement for?
