HI , IS ANYONE KNOWS HOW PUT NODE (PUT JOINT) TO INTERSECTION OF TWO BEAMS WHICH ARE UNEQUAL IN LENGTH (CAN NOT PUT NODE TO MIDDLE AS INTERSECTION IS NOT IN MIDDLE)
You can select the braces and do the following
In STAAD.Pro CONNECT Edition :
In STAAD.Pro v8i :
go to Geometry in the top menu > Intersect Selected Members > Intersect
Answer Verified By: Gulshan Hidayatzade
Hi, thanks a lot Sye for answer, it is worked.
