Dear Forum Members,
I'm doing Time History analysis. After run of model, i'm getting the below warnings,
**WARNING: Time History analysis is being performed with the MASTER-SLAVE command. Forces applied at slave dof will be ignored. Revise these loads so they apply to the master node and add one or more moment components at the master, if appropriate.
*WARNING* MASTER / SLAVE EQUATIONS ARE NOT PROPERLY CONSIDERED IN A TIME/STEADY SOLUTION.
Please help if possible.
Does it mean there is no way to remove this warning & staad is incapable of solving time history loads with master slave command?
