When trying to design a spread footing in RAM foundation, I lowered the rebar quantity while still being above the required amount. Yet the program shows an error for Testing and gives no other information.
There was another report of this yesterday. His case was a small footing, with partially developed rebar. If you send the file and confirm what version you are using I can try to get to the bottom of it.
I am getting the same error message, was there an answer to this issue?
Is your case also a small footing with only partially developed rebar? See: https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/8147/ram-ss---foundation-faq
Try assigning the size manually. Otherwise send the file. Secure File Upload
