STAAD CONNECT v22.01.00.39 - AISC 360-10 Truss Design Check - Incorrect Labeling of Axial Force
Hello!
I have had a colleague come to me with a problem with the latest STAAD CE (v22.01.00.39). They created a simple truss model, and when checking the compression chord (Beam 3) on the outside of the truss, the loading diagram and beam end results are correct (compression), however for the code check for AISC 360-16 STAAD assigns the load as "tension".
Pic1 (CONNECT v22, AISC 360-16)
Img2_CE_AISC360-10 (CONNECT v22, AISC 360-10)
This was checked back to STAAD SS6 v20.07.11.90 and compared to the previous version of CONNECT (v21), and the code check was showing the correct "compression" indicator (see below). Can a fix be provided by Bentley to correct this error? Please verify that this does not happen in the other design codes as well.
SS6 (SS6 v20.07.11.90, AISC 360-10)
STAAD File Attached: /cfs-file/__key/communityserver-discussions-components-files/5932/Truss-Example.STD
Michael Duncanson
